Dietary Amino Acid Source Elicits Sex‐Specific Metabolic Response to Diet‐Induced NAFLD in Mice - Toxicologie Intégrative & Métabolisme Accéder directement au contenu
Article Dans Une Revue Molecular Nutrition and Food Research Année : 2023
Clémence Rives
  • Fonction : Auteur
Céline Marie Pauline Martin
Lauris Evariste
  • Fonction : Auteur
Arnaud Polizzi
Marine Huillet
  • Fonction : Auteur
Frédéric Lasserre
  • Fonction : Auteur
  • PersonId : 1202853
Valérie Alquier‐bacquie
  • Fonction : Auteur
Prunelle Perrier
  • Fonction : Auteur
Jelskey Gomez
  • Fonction : Auteur
Yannick Lippi
Claire Naylies
  • Fonction : Auteur
Thierry Levade
  • Fonction : Auteur
Frédérique Sabourdy
  • Fonction : Auteur
Hervé Remignon
  • Fonction : Auteur
Pierre Fafournoux
Benoit Chassaing
Nicolas Loiseau
  • Fonction : Auteur
Hervé Guillou
  • Fonction : Auteur
Sandrine Ellero‐simatos
  • Fonction : Auteur
Anne Fougerat
  • Fonction : Auteur
  • PersonId : 853989
Scope: Non-alcoholic fatty liver disease (NAFLD) is a sexually dimorphic disease influenced by dietary factors. Here, the metabolic and hepatic effects of dietary amino acid (AA) source is assessed in Western diet (WD)-induced NAFLD in male and female mice. Methods and results: The AA source is either casein or a free AA mixture mimicking the composition of casein. As expected, males fed a casein-based WD display glucose intolerance, fasting hyperglycemia, and insulin-resistance and develop NAFLD associated with changes in hepatic gene expression and microbiota dysbiosis. In contrast, males fed the AA-based WD show no steatosis, a similar gene expression profile as males fed a control diet, and a distinct microbiota composition compared to males fed a casein-based WD. Females are protected against WD-induced liver damage, hepatic gene expression, and gut microbiota changes regardless of the AA source. Conclusions: Free dietary AA intake prevents the unhealthy metabolic outcomes of a WD preferentially in male mice.
Molecular Nutrition Food Res - 2023 - Rives - Dietary Amino Acid Source Elicits Sex‐Specific Metabolic Response to.pdf (6.92 Mo) Télécharger le fichier
licence
hal-04287354 , version 1 (15-11-2023)
Licence
Clémence Rives, Céline Marie Pauline Martin, Lauris Evariste, Arnaud Polizzi, Marine Huillet, et al.. Dietary Amino Acid Source Elicits Sex‐Specific Metabolic Response to Diet‐Induced NAFLD in Mice. Molecular Nutrition and Food Research, 2023, ⟨10.1002/mnfr.202300491⟩. ⟨hal-04287354⟩
30 Consultations
42 Téléchargements
