Skip to Main content Skip to Navigation
New interface
Conference papers
Experimental Characterization of LoRaWAN Link Quality
Takwa Attia 1 Martin Heusse 1 Bernard Tourancheau 1 Andrzej Duda 1
1 Drakkar
LIG - Laboratoire d'Informatique de Grenoble
Abstract : In this paper, we present the results of extensive experiments on a testbed in the The Things Network (TTN), a public LoRa network. We evaluate the transmission quality of LoRa links by measuring the Packet Reception Rate (PRR) as a function of the payload length. The results show that there is only a slight impact of the payload length on PRR, which means that the bit error rate does not strongly influence the probability of packet reception. Our measurements show that the LoRa channel behaves like a slow fading Rayleigh channel, which translates into probability Ps of being (or not) in a favorable condition for each frame reception: once the frame preamble is received, there is great chance that the whole frame is correctly received. Probability Ps depends on the Spreading Factor and the Signal to Noise Ratio, and often becomes a dominant factor of successful reception depending on the signal strength at a gateway.
Document type :
Conference papers
Complete list of metadata
Cited literature [19 references]  Display  Hide  Download
https://hal.archives-ouvertes.fr/hal-02316402
Contributor : Martin Heusse Connect in order to contact the contributor
Submitted on : Tuesday, October 15, 2019 - 11:49:14 AM
Last modification on : Wednesday, July 6, 2022 - 4:16:23 AM
Long-term archiving on: : Friday, January 17, 2020 - 11:50:22 AM
File
Lora_Globecom-ef.pdf
Files produced by the author(s)
Identifiers
  • HAL Id : hal-02316402, version 1
Citation
Takwa Attia, Martin Heusse, Bernard Tourancheau, Andrzej Duda. Experimental Characterization of LoRaWAN Link Quality. IEEE Global Communications Conference (GLOBECOM), Dec 2019, Waikoloa, United States. ⟨hal-02316402⟩
Share
Metrics
Record views
160
Files downloads
681
