Tuning the Valence of MnOx Cathodes Reveals the Universality of the Proton‐Coupled Electrodissolution/Electrodeposition Mechanism in Rechargeable Aqueous Zn Batteries - Matériaux Hybrides et Nanomatériaux Access content directly
Journal Articles Advanced Energy Materials Year : 2023
Abstract
Abstract The charge storage mechanism of manganese oxides (MnOx) in rechargeable mild aqueous Zn batteries is still a matter of debate, with no consensus on mechanism and charge carriers. In this work, this issue is addressed by relying on a quantitative and comparative electrochemical study of low‐valence crystalline MnOx cathodes in a range of aqueous electrolytes, with a primary focus on spinel Mn3O4 . The results demonstrate that the oxidation state of Mn in MnOx structures as well as their degree of crystallinity have little impact on the electrochemical reactivity, all MnOx being fully converted into soluble Mn2+ upon discharge. It is further revealed that this electrodissolution mechanism is affected by Mn3O4 dismutation in the most acidic electrolytes. Accordingly, the true thermodynamics and kinetics of Mn3O4 are only accessible at mildly acidic to neutral pHs. In addition, the study confirms the phase transformation of Mn3O4 to Mn5O8 upon galvanostatic oxidation, and demonstrates that this transformation only proceeds in Mn2+ ‐free electrolytes, since otherwise amorphous MnO2 electrodeposits on top of Mn3O4 . Finally, it is concluded that regardless of the starting MnOx material, after the first discharge or a first charge/discharge cycle, subsequent charge/discharge cycles rely on a reversible proton‐coupled electrodeposition of amorphous MnO2 .
Manuscript_revised version_HAL.pdf (2.78 Mo) Télécharger le fichier
Origin Files produced by the author(s)
Dates and versions
hal-04311450 , version 1 (28-11-2023)
Identifiers
Cite
Arvinder Singh, Christel Laberty-Robert, Véronique Balland, Benoît Limoges. Tuning the Valence of MnOx Cathodes Reveals the Universality of the Proton‐Coupled Electrodissolution/Electrodeposition Mechanism in Rechargeable Aqueous Zn Batteries. Advanced Energy Materials, 2023, ⟨10.1002/aenm.202301745⟩. ⟨hal-04311450⟩
58 View
24 Download
Share
