A network approach to infer the coordinated role of microRNAs on biological processes
Une approche réseau pour l’inférence du rôle des microARN dans la corégulation des processus biologiques
RNA interference is a process in which a small non-coding RNA will bind to a specific messenger RNA and regulate its expression. This evolutionary conserved mechanism is found in all superior eukaryotes from plants to mammals. Nowadays, we know that RNA interference is a major regulatory process involved in developmental biology and tumor progression. MicroRNAs (miRNAs) are endogenous (coded in and produced by the cell) non-coding RNAs which are able to regulate a whole set of genes, typically hundreds of genes. This doctoral thesis consisted in the analysis of the miRNA mediated coregulation through a network approach based on target sharing. Coregulation is the process where many different miRNAs will regulate the same set of genes and thus the same biological process. In particular, the work consisted in the inference of a miRNA network, in its topological analysis and also its biological interpretation. Indeed, the final aim of the work was to generate new biological hypothesis. As such, two different groups of miRNAs were first retrieved. One of them was predicted to be involved in the small GTPase signaling and was further validated in vitro. Moreover, a miRNA community involved in the maintenance of stem cells pluripotency was also discovered. Finally, a systemic analysis of the target-based miRNAs network was conducted to better understand their integration with biologic networks and their role in cell fate.
L'interférence par l'ARN est un processus selon lequel un petit ARN non codant se lie à un ARN messager cible dans la cellule pour moduler son expression. Ce mécanisme a été conservé au cours de l'évolution : il est retrouvé aussi bien chez les animaux que chez les végétaux. Nous savons aujourd'hui que le rôle de l'interférence par l'ARN est fondamental, dans le développement embryonnaire comme dans la progression tumorale. Les microARN (miARN) sont des ARN non codant endogènes dont l'une des particularités est leur capacité à réguler tout un ensemble de gènes par interférence avec les ARN messagers. Il est ainsi prédit qu'un seul miARN serait capable de réguler plusieurs centaines de gènes différents. La thèse a consisté en l'analyse de la corégulation médiée par les miARN grâce à l'inférence de réseau basée sur le partage de gènes cibles. La corégulation est un phénomène où plusieurs miARN différents interviennent sur les mêmes familles de gènes et donc sur les mêmes processus biologiques. Le travail a plus spécifiquement consisté en la mise en place d'un réseau de miARN, en son analyse topologique mais également en son interprétation biologique. Le but final était de proposer de nouvelles hypothèses biologiques à tester afin de mieux comprendre la corégulation des processus biologiques par les miARN. Au travers de ces travaux, deux groupes de miARN ont pu être mis en évidence, dont l'un impliqué dans la régulation de la signalisation par les petites GTPases – hypothèse par la suite validée par plusieurs expériences in vitro. Dans un second temps, une communauté de miARN impliquée dans le maintien de la pluripotence des cellules souches a pu également être mise en évidence. Pour compléter ces analyses, une étude systémique de la topologie des réseaux de miARN a été menée afin de mieux comprendre leur intégration dans les réseaux biologiques et leur rôle dans le devenir cellulaire.
