La protéine kinase LegK2 de Legionella pneumophila et le complexe ARP2/3 de la cellule hôte : un nouveau paradigme dans le détournement du cytosquelette d'actine par un pathogène - CIRI - Pathogenèse des légionelles Accéder directement au contenu
Thèse Année : 2015
The protein kinase LegK2 of Legionella pneumophila and the ARP2/3 complex of the host cell : a new paradigm in the actin cytoskeleton hijacking by a pathogen
Legionella pneumophila is an opportunistic bacterium that emerges from the environment after multiplication in protozoans and can accidentally infect human alveolar macrophages leading to a severe pneumonia, the legionellosis. The L. pneumophila ability to survive within host-cells is strictly dependent on the Dot/Icm Type 4 Secretion System that translocates a large repertoire of effectors into the host cell cytosol. Deciphering the individual contribution of each bacterial protein translocated by the Dot/Icm system in the L. pneumophila infectious cycle remains a major challenge to understand the molecular basis of Legionella virulence. My works contribute to this objective by characterizing the cellular pathway targeted by the protein kinase LegK2. Interaction and phosphorylation assays identified the actin nucleator ARP2/3 complex as the target of LegK2. Following the LegK2 addressing to the vacuole surface after its translocation into host cytosol, LegK2- ARP2/3 interplay inhibits the actin polymerization on the phagosome. This inhibition allows Legionella to decrease the late endosome/lysosome trafficking towards the phagosome and promotes the phagosome evasion from endocytic degradation pathway. LegK2-ARP2/3 interplay highlights an original mechanism of virulence wherein the local actin cytoskeleton remodeling of host cell allows bacteria to hijack the vesicles trafficking in order to escape host-cell defenses
Legionella pneumophila est une bactérie opportuniste qui émerge de l'environnement après multiplication dans des amibes et peut infecter accidentellement les macrophages alvéolaires humains, provoquant une pneumonie sévère, la légionellose. La capacité de L. pneumophila à survivre dans ses cellules hôtes est strictement dépendante du système de sécrétion de type 4 Dot/Icm, qui sécrète un large répertoire d'effecteurs dans le cytosol de l'hôte. Identifier la contribution individuelle de chaque protéine bactérienne sécrétée par le système Dot/Icm, dans le cycle infectieux de L. pneumophila reste un enjeu majeur pour comprendre les bases moléculaires de la virulence des légionelles. Mes travaux de thèse participent à cet objectif en caractérisant la voie cellulaire ciblée par la protéine kinase LegK2. Des tests d'interaction et de phosphorylation ont identifié le complexe nucléateur d'actine ARP2/3 comme cible de LegK2. Suite à l'adressage de LegK2 à la surface de la vacuole après sa translocation dans le cytosol de l'hôte, l'interaction LegK2-ARP2/3 inhibe la polymérisation d'actine sur le phagosome. Cette inhibition permet à Legionella de diminuer le trafic des endosomes tardifs et/ou des lysosomes vers le phagosome et favorise ainsi l'évasion du phagosome à la voie de dégradation endocytique. L'interaction LegK2-ARP2/3 met en évidence un mécanisme original de virulence dans lequel le remodelage local du cytosquelette d'actine de la cellule hôte permet à la bactérie de manipuler le trafic vésiculaire pour échapper aux défenses de l'hôte
TH2015MichardCeline.pdf (20.39 Mo) Télécharger le fichier
Loading...
tel-02967463 , version 1 (15-10-2020)
  • HAL Id : tel-02967463 , version 1
Céline Michard. La protéine kinase LegK2 de Legionella pneumophila et le complexe ARP2/3 de la cellule hôte : un nouveau paradigme dans le détournement du cytosquelette d'actine par un pathogène. Microbiologie et Parasitologie. Université Claude Bernard - Lyon I, 2015. Français. ⟨NNT : 2015LYO10181⟩. ⟨tel-02967463⟩
170 Consultations
18 Téléchargements
