Évolution paléogéographique et karstogenèse du bassin d'Issirac (Gard, France) du Crétacé supérieur au Miocène inférieur - SPIN - Sciences des Processus Industriels et Naturels Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
Since the emergence of the carbonated platform of the southeastern basin of France during the Albian-Cénomanian, a long process of complex polyphased karstification is being installed under joint influence of tectonics, eustatism and climate. The endorheic basin of Issirac includes terrains from Cretaceous until Eocene age. Connected to the Alès groove, it has been undergoing eustatic variations combined with flows coming at the same time from the Cevennes and, apparently, from the installing endokarst in the regional carbonated platform englobing the plateau of Méjannes-le-Clap, located in the north of the Gard department, and the Cèze-Ardèche interfluvium. These observations underline a karstogenesis going back to late Cretaceous and early Paleogene times, related to the installation of a basin in conjunction with a planation surface in and on which redesigned sediments have been deposed of which, at present time, only relics remain. Nevertheless its poor visibility at the level of Paleocene and Eocene terrains of the Issirac basin, the karstogenesis permits to observe in the underlying limestone levels of the late Barrémian and Aptian (Bédoulian), indications of excavation whose infillings show strong proportions of alterites containing minerals of volcanic or magmatic origin coming from the Central Massif. The development of karstic aquiphers is orienting hypogeous drains towards successive base levels installing into the endorheic basin during the same periods, before their accomodations during Oligocene and Miocene times. This dynamic is modeling new endokarstic shaping of various gradations. The most recent geological in situ observations are indicating a progressive inversion of hypogeous drains changing from sedimentary base level aggradations formed by the endorheic basin of Issirac towards those of successive low levels related to the incision of Cèze and Ardèche rivers during Cenozoïc eras.
Depuis l'émersion de la plate-forme carbonatée du bassin du Sud-Est de la France à l'époque de l'Albien-Cénomanien, un long processus de karstification complexe et polyphasé se met en place, sous les contraintes conjointes de la tectonique, de l'eustatisme et du climat. Le bassin endoréique d'Issirac comprend des terrains allant du Crétacé à l'Éocène. Connecté au sillon d'Alès, il a été soumis à des variations eustatiques combinées à des écoulements provenant à la fois des Cévennes et vraisemblablement de l'endokarst en cours d'édification dans la plate-forme carbonatée régionale qui englobe le plateau de Méjannes-le-Clap, situé au nord du département du Gard, et l'interfluve Cèze-Ardèche. Une karstogenèse s'instaure au Crétacé supérieur et au début du Paléogène. Elle est liée à l'installation d'un bassin et la formation d'une surface d'aplanissement où se déposent des sédiments remaniés dont il ne reste à ce jour que des reliquats. Peu visible au niveau des formations du Paléocène et de l'Éocène du bassin d'Issirac, la karstogenèse laisse entrevoir dans les assises calcaires du Barrémien supérieur et de l'Aptien (Bédoulien), des indices de creusement dont les remplissages contiennent en forte proportion des altérites présentant de minéraux d'origine volcanique ou magmatique en provenance du Massif Central. L'élaboration d'aquifères karstiques oriente des écoulements hypogés dirigés en premier lieu vers les niveaux de base successifs s'établissant dans le bassin endoréique au cours des mêmes périodes puis leurs accommodations au cours de l'Oligocène et du Miocène. Cette dynamique modèle des nouveaux façonnements endokarstiques de diverses ampleurs. Les dernières observations géologiques in situ mettent en exergue un changement de direction progressif des écoulements hypogés passant ainsi des aggradations sédimentaires du niveau de base constitué par le bassin endoréique d'Issirac à des points bas successifs liés à l'enfoncement des cours d'eau de la Cèze et de l'Ardèche durant l'ère Cénozoïque.
Jolivet - Évolution paléogéographique et karstogenèse du bassin d'Issirac du Crétacé supérieur au Miocène inférieur.pdf (1.46 Mo) Télécharger le fichier
Loading...
hal-01612184 , version 1 (06-10-2017)
  • HAL Id : hal-01612184 , version 1
Joël Jolivet, Hervé Chapuis, Jordan Ré-Bahuaud, Didier Graillot, Bernard Guy, et al.. Évolution paléogéographique et karstogenèse du bassin d'Issirac (Gard, France) du Crétacé supérieur au Miocène inférieur. 2017. ⟨hal-01612184⟩
590 Consultations
705 Téléchargements
