Liquid Processing of Bismuth–Silica Nanoparticle/Aluminum Matrix Nanocomposites for Heat Storage Applications - Matériaux Hybrides et Nanomatériaux Accéder directement au contenu
Article Dans Une Revue ACS Applied Nano Materials Année : 2022
Metal matrix nanocomposites encompassing low-melting point metal nano-inclusions are promising candidates for thermal regulation of devices at high temperature. They are usually processed by solid-state routes that provide access to a limited range of materials and are hardly compatible with complex shaping processes and with large-scale applications. Herein, we develop a liquid-phase processing technique to design aluminum matrix nanocomposites made of phase change nanoparticles, using bismuth nanoparticles as a proof-of-concept. The bismuth nanoparticles derived from colloidal chemistry are first encapsulated in a silica shell and then dispersed by ultrasonication into molten aluminum. Using X-ray diffraction, electron microscopy, and X-ray photoelectron spectroscopy, we probe the evolution of the bismuth particles and of the inorganic shell. We demonstrate that the silica shell acts as a barrier against extensive coalescence of particles during the dispersion process, thus enabling a decrease and a widening of the phase change temperature range.
acsanm.1c03534 for HAL-2.pdf (7.92 Mo) Télécharger le fichier
hal-03560991 , version 1 (07-02-2022)
Binghua Ma, Walid Baaziz, Léo Mazerolles, Ovidiu Ersen, Bernard Sahut, et al.. Liquid Processing of Bismuth–Silica Nanoparticle/Aluminum Matrix Nanocomposites for Heat Storage Applications. ACS Applied Nano Materials, 2022, pp.10.1021/acsanm.1c03534. ⟨10.1021/acsanm.1c03534⟩. ⟨hal-03560991⟩
69 Consultations
81 Téléchargements
